ChattingLil
I was about to repair/service the water pump on a VP2002. I can only access the engine from the front and by some contortion over the top front quarter. The water pump has a metal pipe leading back and I can't get at it without removing the water pressure canister thing and other obstructions. This coming weekend, I will remove all the obstructions so that I can get to the end of the pipe - the pipe then attaches into short piece of hose. My question is this: is there any reason why I should NOT cut the metal pipe and replace it with a longer piece of hose while I am in there and have access? That way, if I ever need to remove the pump again it will be much easier - ie I won't have to remove all the gubbins to get at the back end of it to unclip the long pipe.
