blueandy_a
Hi
I have a problem with my engine. Its a volvo 2002 (1991) fitted to a Westerly Merlin. I removed the heat exchanger to fix a salt water leak at the rear plate. Reassembled and fitted the heat exchanger taking care to align the rubber gaskets. After starting the engine and running for 30 mins or so, the engine warning siren came on along with the engine oil warning light. There is plenty oil in the engine, no oil leaks and no burning oil coming out of the exhaust.
I think the problem may be the fresh water coolant temperature as the thermostat housing is really hot as is the pipe from there into the heat exchanger; however the fresh water outlet pipe from the heat exchanger is really cool suggesting the fresh water is not circulating.
The sea water system is fine and running into and out of the heat exchanger and out of the exhaust. I removed the heat exchanger again and all the water runs free through it on both fresh and salt water.
There is a calorifier fitted - could this be airlocked and cause a lack of circulation and if so how would it be bled? The other part i'm going to check is the thermostat and lastly the water pump.
If you can give any advice I would be very grateful.
Andy
Andy
