VicS
I am not convinced it will. The front housings also contain bearings and seals and from memory the legs of the 120 are different from the 130/150 type with the split anode. Think the shaft may be longer as the anode and housing are longer. However, the parts drawing posted by Nigel suggests that housing will fit, but it confuses me as the 120 leg went out of production in around 2005. I tried to buy a new one in 2011 but could only get a 130 leg complete - but that diagram is showing a price for the whole assembly which would suggest if it is current that the assembly is still available.
BTW the latest Keyparts catalogue shows the prop locking screw as having loctite in the threads rather than the plug. The new one I bought from Volvo in 2011 also was of this type. Also all the listings for anodes for the 120 leg are still the one piece ring.[/QUOTE]
I think you are right.
The propshaft the bearing, shim and seals are the same
The legs themselves look very different.
The bearing housings are different and the O ring seals between it and the leg are different.
