johnsilver2
Active Member
Good Day,
I have just bought a replacement alternator for the Paris Rhône fitted to my Volvo 2002 and I’m having a problem with the D+ terminal.
When fitting the charging indicator lead to the D+ the indicator light does not come on when the engine is not running. The oil pressure warning light and alarm come on! If I earth the charge indicator lead every thing comes on as it should. I confirmed all was ok with the Volvo panel by reconnecting the Paris Rhône.
Anyone else replaced the old Paris Rhône with the latest replacement sold by Keypart etc?
I connected the charging indicator lead to the W terminal and the warning light came on but stayed on when the engine was running. The alternator was pushing out 14.3V so no problem there. I don’t think the W terminal has a high enough voltage to put out the warning light as it just feeds the Rev counter. I borrowed another new alternator and had the same problem so it look like the D+ terminal is different on newer generic replacement alternators for the Volvo Paris Rhône.
Regards..........Andrew
