volvo mono shift gear box. slipping in reverse.
  • Start date Start date
G
Guest
Guest
my 1975 MS gearbox. is slipping in reverse. i have dismantled the box. and can see a wear differance between the two cone linnings. does anyone know. if the linnings can be bought loose. or part exchanged.
i have a workshop manuel covering the gearbox. but its in swedish. and a bit of a struggle. does anyone have an english version they could scan and mail.
good sailing to those who can get out.
Re: volvo mono shift gear box. slipping in reverse
I may be able to help if you could let me have your email address?
Chris
I need the same help is possible
Hi,
I have the same problem Im afraid, I have dismantled the box and the conical linings have deteriorated, I would appreciate the manual in english as I need to remove the forward gear in order to send them both to a company in the UK who can reline the housings.
If would appreciate any help is possible
Kind regards
Dave Connell
Thanks for the response,
Im not sure if thats the same box or not ?, Im a little confused about which box I have its definitely an MS, the engine is an MD7a, Im not sure your box would be compatible.
I will look into this and get back to you.
thanks again
Dave
