WotSandbank
Waterpump seals is one thing to consider esp if 10 years old.
For the reasons above you should/may notice water leaking from the pump before the water seal becomes so badly worn that water is forced into the engine via the oil seal.
If the water injection into the exhaust is not several inches above the water line you should have a raised loop in the hose leading to the injection point with an antisyphon valve at the highest point.
Check the valve for correct operation. A defective valve might explain water in the oil initially even if not how it may be getting in while recirculating.
The head gaskets are a possibility. Dont rush in to change these. They cost an arm and a leg so check cheaper things first.
If your engine has brass drain cocks ( or plugs) on the cylinder blocks perforation of the cylinder wall due to electrolytic action may be a possibility. It can happen, I understand, to the liners in an MD11 but I do not know if it happens to an MD2B
You may not have got rid of all the water when you drained the old oil. What you are seeing now may be water that remained after draining the oil esp if you sucked it out via the dipstick fitting rather than via the sump drain plug.
I'd feel inclined to flush the engine with the cheapest engine oil that you can find . ( Asda ?)
You dont say if you have the manuals. If not you can find the Owners manual on VP's website http://www.volvopenta.com/volvopent...lication_search/pages/publication_search.aspx
and the workshop manual at http://www.bluemoment.com/downloads.html
_______________________
Thanks VicS yes i have manuals both paper and electronic. I spoke to a friendly marine engineer i use sometimes and he said the seals were a good starting point. He felt the back syphoning was unlikely although he did say a lot of folk put buckets above the engine (usually in the cockpit) and after the engine is stopped it continues to syphon and eventuall can fill up the water jackets until it reaches the manifold and then into the engine. So if I find the water seals are ok this could explain the water ingress. Although the bucket I slung over the transom was probably below the engine, the 10ft length of pipe was not. He thinks this wouldnt have caused it but on the other hand may just.
He did say with new oil it diesnt take much to emulsify it. We shall see
