Mastermuffin
New Member
Recently swapped out my Perkins m50 for a rebuilt Volvo Md22, I had test started it in my garage for a few minutes and noticed no smoke from the exhaust but discovered someone had messed with the glow plug wiring causing them to stay on. Fixed that issue and test ran it again for a few minutes before putting it in the boat, this time i did notice a bit of smoke on startup but it seemed to go away.
Now that its in the boat it has started smoking and throwing a nasty sheen on the water, especially when cold.
It seems there are quite a few here with experience with these engines so maybe you guys could help!
Ive tried switching to a different fuel source, had the injectors tested, changed the oil and fuel filters, as well as taken it out and ran it between 1600 and 2500 rpm for a few hours now.
Here's a video of the engine running now that its in the boat.
