ukyachty2
Hi, I have a lot of alternator belt wear now that I fitted a charge controller on the alternator. Its not on start up, it's just the 40 amp load over an hour or so. I am cruising on an old Westerly in the Caribbean. Ideally I would like to use a 90 amp alternator as on the Volvo D1-30 with poly-V pulleys. Since the engines are very similar (apart from the air cleaner and heat exchanger), I thought it might be possible to use the pulleys from the D1-30. Can I do this, or is there another way that's going to be relatively inexpensive? Look forward to the discussion.
