VicS
Your symptoms fit with a loose circulation pump impeller, although I know nothing about a 2020 circulation pump in particular. Often the impeller/turbine is just pressed onto the end of the pump shaft and I've seen a few that have become a loose fit. They tend to keep up at low revs and everything runs fine but then they start to slip at high revs and don't provide enough coolant circulation. Just an idea..
Interesting thought.
It looks like this and is not user serviceable
On the subject of pumps, although I dont think it applies in this case, flexible vane pumps that are driven by a key acting on the hub of the impeller are known for the impeller to slip on the hub sometimes.
