Jokani
My Volvo MD2020 will not rev for 30 seconds after starting, and has white smoke or steam in the exhaust , except for when warm with a few revs on.
I have eliminated the following possible causes:
1) Air in the fuel (fitted clear pipe)
2) Fuel injection issue (professionally spill tested)
3) Cam shaft/timing gear (Cover removed and verified timing correct)
4) New Johnson raw water pump (100 hours so no/very litle wear)
The engineer that conducted the spill test could not find a problem with the fuel injection system, but said that the compression seemed extremely high and that combined with the smoke made him think that the cam shaft/ timing gear could be one tooth out. Last weekend I removed the timing gear case, and unfortunately it was correct, which still leaves me with the problem, plus I found emulsified oil and water in the timing gear case, injection pump housing and oil filler, but not in the dip stick which I had been checking.
Next step, this weekend, remove the head to check that and see what I find.
I can't afford to have the work completed professionally, so the task falls to me this weekend, but I have never removed a head before.
Looking through the Volvo workshop manual it seems a relatively simple process, but I thought it would be wise to see seek any general tips on head removal here, or maybe I could be lucky and someone here has experience of removing an MD20x0 head?
Thanks in advance.
Thanks in advance.
