fulmarnyc
Situation started when bolts on freshwater pump came loose, spraying quite a bit of coolant all over my engine bay. Immediately killed engine, fixed pump issue, let engine, cool and then restarted without a problem. Later that day, and since then, engine won’t restart. Temp and oil pressure gauges normally tick up when key is turned on, now they don’t move. When I turn the key to start, there is no noise or movement from the solenoid or starter. Cabin lights don’t dim when I turn key to start. Nothing happens when I bridge solenoid main to ignition wire or bridge two solenoid mains. Voltmeter connected to the two solenoid main leads shows 12.8V when key is off, 1.6 V when switch is on and drops to millivolts when key switch is turned to start. Next steps? Any ideas on what is going on here?
