Bobc
Just looked at the VP datasheet, and recommended operating speed is 2600-3000rpm.
It is a car engine which revs to 4300rpm.
Recommended cruising revs is 3,000 - 3,300, although that's a bit much, but at least 2,500.
Run it at 2,000rpm and it's not getting up to full working temperature.
It might be based on a car engine but our Perkins M50 won't do more than about 2600 out of gear. It's a marine engine that's very conservatively rated. I'm happy about that as, hopefully, it will go on for ever!
Cruising speed
Operating the engine at wide open throttle (WOT) should be avoided since it is both uneconomical and uncomfortable. Volvo Penta recommends a cruising speed in the range 300 - 500 rpm lower than maximum rpm at WOT. Depending on hull type, choice of propeller, load and conditions etc. the maximum engine speed at top speed can vary, but it should be within the WOT range......
There recommendion are set to work with there three fixed blade propeller or their two blade folded ,
once you start changing stuff the recommendations goes out of the window ,
Then you have to take all the other stuff in consideration, and again it just a recommendation.
By the way the MD 22 isn't a Volvo engine .
You should cruise a diesel at about 2/3 to 3/4 of it's rated rpm. Diesels need to run hot.
Bob, not wishing to get in to a pissin contestbut a diesel engine can be flat out at less than rated full revs. Put a heavy load on it by over propping a bit for example can in theory make the governor open the rack fully to keep the revs at the throttle indicated range.
My prop is a 16 by 16 three bladed one, allegedly not standard Beneteau, allegedly over size. It gives me 6 -7 kts at 2100 rpm. If I go to full throttle it will rev to about 3200 BUT the speed doesnt go much better, the stern squats and serious black smoke is emitted. So my engine is loaded at 2100, up to temperature and yet is economical
normal rule of thumb, 1 ltr per hr per hp used
:encouragement:Our 42 foot MD 22P 1800rpm 2lph 2000 rpm 2.5 LPH
I keep a very close eye on this , my filler is in the cockpit floor , so I tend to fill to the top of the filler then next time do the same and compare with engine hours .
How do you all measure your fuel consumptions, bearing in mind that roughly half the diesel drawn from a tank returns to it?
This seems pretty good:
:encouragement:
:encouragement:
I was nearly caught out a number of years ago when running my engine from an emergency can of diesel as a "get you home" measure with a blocked tank output pipe.In my case it's petty accurate I would say , my filler is in the cockpit floor , I record engine hours and gen hours , each time I fill with fuel and top right up to about a few ins from the top of the filler .
20litres seemed like lots for ~20miles with my BetaMarine ~33hp/Moody336 - but the can seemed awfully light about halfway home.
I realised some fuel was "returning" to the tank - as I was putting the sails up!![]()
