Fhvera
New Member
When I turn the ignition nothing happens. No cranking then mysteriously it cranks and runs perfectly.
I presses the battery parallel button and started without any problems. So it might be a battery issue. ThanksAssuming the battery posts are clean + leads tight ? ..
How salty are the ignition barrels and there connections ?
Next if fitted how salty / ver d Gris are the fire suppression system engine shut down connections ?
