BruceK
I had to drain both engines to get the oil coolers out.
Where as the owners manual is full of info on draining the system it's a bit pauce on refilling it so...
Question 1 - For the fresh water & antifreeze coolant, when filling up is there a air bleed bolt / valve that needs to be loosened. How do I go about checking that there is no air locks? What rough capacity (for a 50-50 premix).
Question 2 - Raw water coolant. Does this need to be topped up and if so from where, or any other procedure i.e. to avoid impeller damage (the impeller sits about a foot above the water line). Do I need to check for any air locks here?
