AdrianPetts
My Volvo MD2040D has developed a leak of coolant from the heat exchanger. It seems that a hairline crack has developed around the base of the filler neck, the part that the filler cap fits onto. At first I thought it might be a problem with the filler cap but after replacing with a new, and expensive, Volvo replacement the problem still persists. On close examination one can see small water bubbles being blown out around the joint between the filler neck and the housing body. This is leading to a loss of coolant which runs down the engine block and into the bilge. About one third of a cupful is being lost per hour. Absolutely nothing is coming down the expansion overflow tube, which I have checked to ensure its not blocked.
Has anyone experienced similar problems? Is there a fix short of a new heat exchanger housing? Is the filler neck part of the housing casting or is it somehow fitted, by pressure of screwing, to the housing body?
This is not a case of salt water entering the fresh water system and being expelled through the overflow. I have had experience of that previously and the symptoms are very different.
All positive advice greatly appreciated.
