inspirit
I have a 6 year old Beneteau fitted with a Volvo engine and marine exhaust. The exhaust is made up of two stainless end caps with a large rubber flexible hose between. A small pinhole leak has occurred where the stainless exhaust outlet passes through the end cap. Just on one side of the weld there is corrosion and it appears to be worse on the outside. I've wire brushed all the corrosion products and cleaned the whole area. The outside of the stainless cap is heavily pitted while the inside surface shows no corrosion, just some small pinholes.
Also there appears to be corrosion underneath the rubber feed and outlet tubes but this looks different, just like its been etched by acid.
I'm suspicious this is electrolytic action and wondered if anyone has had the same experience. Also would connecting the stainless caps to an anode connection help prevent this happening again
