jukohaka
Hi,
Been an avid reader of the forum and especially appreciated the expertise & precision of discussion on engines and related questions. Volvopaul, Spannerman and the many of you - I am a fan
Also, have been one of the unfortunate owners of early D3-190 after a switch from AD31P - have learned to try do my homework as much as possible before switching.
Now, have a longer term dream of buying a Benny Antares 10.80 with either a pair of KAMD44's, 300's or D4-260's and seek for point-of-views concluding many of the discussions on this site. In earlier threads, have noted e.g. following:
KAMD44/300:
- Almost an identical engine?
- Cylinder block that can also be drilled / over sized
- More complex than the solid KAMD43, 1st generation of EVC electronics causes some challenges from time to time
- Valves require sustained adjustment every 200hrs
- Lubrication system "old-school" and may cause challenges if run often and extensibly in displacement speeds
- Multiple belts require attention in maintenance schedule
D4 260:
- Completely new engine back in 2006, multiple update solutions & recalls
- Smaller in lateral / longitude size --> more space in engine room
- Slightly better fuel efficiency than above
- Electronics abound, fragile re: fuel quality and sometimes also re: moisture accumulation from intake air
- Many testimonies on replaced nozzles and HP pumps (expensive, know from D3 past
- For some reason (compressor?), 260 gets more praise than e.g. 225 in reliability
So, here's a request out to you:
1) Have I gotten the above right?
2) What would be your choice assuming boats with a pair of D4's prices run 10-15k£ higher?
3) Any views in comparison of KAMD 44 and 300 - are they identical in terms of reliability and weak spots?
Look forward to the discussion.
/J
KAMD44/300:
D4 260:
/J
