Volvo engineers? Necessary?
alant
30 May 2001
UK - Solent region
My SIL, has bit the bullet & is buying a Moody 31, currently in Gosport.
The current owner, has only had the boat a very short time (getting divorced) & previous owner has shed his mortal coil, but seemed to take some care with the boat whilst alive. Boat has not been heavily used.
During discussions with the broker, the question of the engine arose & several options have been suggested.
This is one reply from a dealer
"Thank you for the email and email with information of service/ work carried out, I can see from the service history that this vessel hasn’t had the best of service, the Volvo invoices are for none service items the knowing XYZ marine they would possibly have obtained genuine Volvo parts but they are not Volvo engineers and ABC marine have used none genuine parts completely.
With this in mind and we have never had any dealing with this vessel I would strongly suggest a full major service using genuine Volvo parts and engineers.
Please find below what we could be doing for you as a Volvo super centre,
1, carry out an engine inspection at Gosport £53-£424 the range is from visual inspection to full inspection and sea trial with oil analysis.
2, Full bi annual service as listed below
Oil Filter 22057107 1 £13.80
Fuel Filter 829913 1 £11.70
Impeller 21951342 1 £20.20
Service Kit (contains above) 877194 1 £38.20
Anode (RWC only) 838929 1 £6.70
Pre-Filter 3581078 1 £9.50
Drive Belt 973534 1 £12.70
R/cover Gasket 859043 1 £12.60
R/cover Seal 840442 2 £10.00
Oil 1ltr 3840002 4 £25.60
Oil 5ltr
Coolant 5ltr 1141674 1 £11.70
Total engine parts £127.00. if sail drive a further £74.80 in parts, labour engine saildrive £53 per hour @ 5hrs £265 all plus vat.
I hope this is of help to you and if you have further question please feel free to contact me at the office or by email."
Bearing in mind, feelings with some on here, regarding Volvo's, how would you proceed if buying?
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
I have a Moody 31 and a Volvo 2003. Most people use alternative fuel and oil filters. These engines are very common and unsophisticated - any engineer worth his salt can deal with them. Filters area simple diy job. The fuel bleed screw is on top of the filter housing. Oil is another rip-off. Mineral oil 20-50w about £10 for 5 litres at my local car spares place.
Get someone to look it over, make sure the mounts are OK and that the exhaust elbow hasn't blown. Basic service unless it sounds like a can of nails.
Filter list
Boat Filters for Volvo 2001, 2002 and 2003
Oil
Volvo
834337-8
Crosland
659
Unipart
GFE 210
Wix
WL7064
Main Fuel
Volvo
829913
Bosh
N4051
Reisse
48100029
Crossland
5003
Bosh
1457434051
Man
WK 7122
Guttmann
503590071
£3.79 + VAT
Euro Car Parts
(Euro Ref: 503 59 0071)
Hengst
from Europarts
503590070
£3.49 + VAT
Water Separator
Volvo
3581078-7
Bosh
N4201
Unipart
GFE 5296
Hengst
E75K D42
£3.58 + VAT
Euro Car Parts
(Euro Ref: 503 74 5080)
Spyro
18 Jan 2003
Clyde
hahahahah
"Please find below what we could be doing for you as a Volvo super centre,"
shouldn't that also say. Other super centres are available........
Sandy
31 Aug 2011
On the Celtic Fringe
duckduckgo.com
Find an engineer who will do a survey for you.
If that is OK, find a good engineer who will service the engine, this need not be a Volvo engineer, and get a price for a full service.
Consider the findings of the survey and the price full service, at Volvo prices, and adjust your offer accordingly.
johnalison
14 Feb 2007
Essex
The fact that engine has not been heavily used is not necessarily a good sign. I imagine the engine is a 2002 and it would be better if fresh water cooled.
The prices seem to my non-specialist eyes to be fairly normal but there is a large potential bill with the saildrive diaphragm change. Personally, as a non-engineer, I would want to start off with the knowledge that my engine had been fully sorted out and would be looking to negotiate with the seller about the cost of this. Much of the work on these engines is within the ability of many competent owners but it depends on your SIL's abilities how much he wants to undertake himself.
MoodySabre
24 Oct 2006
The standard engine is a 2003 and they are all shaft driven not saildrive. Many were raw water cooled but I guess that a large number have been coverted to fresh water cooling (as was mine). Volvo do a kit for that.
When I bought mine there were some obvious issues with the engine and having all of those sorted by an Volvo engineer at the vendor's expense was part of the deal when I made an offer.
stuartwineberg
24 Oct 2007
Romsey, Hants
Have a word with VolvoPaul over on the mobo forum. He services loads of the boats on the forum, is a good bloke and will also go out with you on the seatrial and stick his head down the engine bay at full throttle - and that will let you know what is happening!
Oil 5ltr
Bobc
20 Jan 2011
If it starts quickly, and runs well with no excess smoke , knocking, or vibration, then it's almost certain to be fine. Clock it into forwards and reverse on the pontoon and give it a minute under load against the warps.
No matter what its service history, you should do a full service on it when you get it anyway (and do it yourself so you get to know the engine).
jac
10 Sep 2001
Home Berkshire, Boat Hamble
+1 for Volvo Paul. We have used him a couple of times, did a great job, Volvo specialist, very reasonable. Boat at swanwick so just up the road.
TQA
20 Feb 2005
Carribbean currently Grenada
sailingonelephantschild.blogspot.com
Plus one on the above . The only thing I would add is to run it at full throttle for at least 10 minutes on the sea trial and observe the temp. and oil pressure gauges closely. A small rise in temp is OK but it should stabilize, the oil pressure should NOT drop although on idle a slightly lower pressure than before is acceptable. Some smoke is acceptable. Getting an experienced diesel spanner monkey to stick his head into the engine compartment and listen to the engine at speed under load is a very good investment.
tyce
6 Jan 2004
cumbria
I have a moody 31, great boats and the volvo is pretty much bomb proof, non volvo serviceable items are used commonly and no cause for any concern. Enjoy. Oh and join the moody owners assoc as has already been mentioned it's an excellent resource.
johnalison
14 Feb 2007
Essex
Thanks. I was a bit surprised to see saildrive in the OP but I supposed the engineers were just listing all their services. I'm also surprised to see that the 31 has the 2003. That must just about get them on the plane with a decent prop!
MoodySabre
24 Oct 2006
It's 28HP with a fixed two-blade prop. At easy cruising revs around 2000 that will get me 5.5knots in flat water no tide (only really achieved in Holland!). A Bruntons for an extra knot would be nice!
Perhaps you were thinking it was the turbo version of that engine.
Sans Bateau
19 Jan 2004
Oil 5ltr
Hee He he! "I'm going to put the fear of God in you, then rob you blind"!
tyce
6 Jan 2004
cumbria
Surprised at the speed you get at those revs, my 31 bilge keel at 2000rpm is well over 6 knots no matter the weather (within reason), I rarely run it above 1850 revs as that gives me the 6 knots, I guess it's just down to different pitch of the propellor mine is also a fixed 2 blade. If you really wind the engine up the stern wave is quite something to behold!
alant
30 May 2001
UK - Solent region
This is it (broker details) -
"Volvo Penta model 2003 28hp diesel engine. Serviced 2012"
also evidence of invoice for a Kiwi Prop.
Pinnacle
6 Jan 2006
Another vote for VolvoPaul of this Parish. He has done our engine service. Lots of recommendations on YBW for him.
