Tafflad
Looking to change my boat.
Current boat and new boat almost identical in terms of length, width, beam, hull type.
22', 8'4", 3,400LB and a 20 degree vee hull
The current boat has Mercruiser I/O V6 200hp and standard Alpha drive, and easily provides all power I have needed.
Looking to get myself a Volvo Aquamatic this time .. like the idea of fresh water cooling, as all my use is in salt water, plus the variable valve timing & direct injection has many benefits.
All Aluminum means a lighter package. (been lots of problems with Mercury Bravo III drives)
Dilemma is what do I get ... would be the V6 motor, but do I get 240hp or pay £2k more and get 280hp
You would think it easy choice go for larger HP .... but looking at performance there is no difference in power up to 4600rpm , and torque is almost identical .... difference only comes in 4600 to 5800 which is not the Rev band I normally operate in.
The 3 graphs tell a lot ... see file at
https://www.dropbox.com/s/l85mgpabq68qt66/volvo.pdf?dl=0
(I could not attach due to forum limit)
Getting extra 40hp and duoprop in itself will be a big boost ... going 280 may not be worth extra cost.
Advice/comments welcome.
