Steve P
Hello All
Here we go, hopefully someone may have an answer!! Volvo engine aq145a Will not start it does crank over but no start, what we have done so far, engine stripped sent to engineering shop for inspection Cylinder block =good Cylinder head=good, rebuilt carburettors with new gaskets jets etc, fitted electronic ignition distributor, new timing belt fitted as follows, camshaft index dot lined up with camshaft cover notch intermediate shaft pulley lined up with single line on cam belt and index dot on pully same as camshaft single line on cam belt, double line on cam belt lined up on crank pulley Engine at tdc 0 deg rotor arm pointing to plug number one rotation clockwise viewed from side of engine looking at distributor cap firing order 1342 as book spec, We reset the TIMING BELT to 6deg btdc the engine did try to start however would not run and backfires. plus the only way we could any sort of run was constantly moving the throttle lever effectively using the accelerator pumps on the carbs to squirt fuel into the engine this eventually leads to engine flooding and more backfires not good, we have noticed the spark plugs are fitted with resistors "R" in the model number for spark plugs indicates resistor fitted, learn something new every day the volvo book states spark plugs with no resistor, new plugs ordered, Am i missing something set up the engine timing wrong we have now put the timing belt back to 0 tdc been told the Solex PA1 is problematic and very difficult to get correct even when new ours are old units Any help suggestions much appreciated Forgot to add new pistons rings have been fitted and bores honed compression is very good as per machine shop Thanks Steve P
