MagicalArmchair
So coming back across the Thames on Tuesday, I didn't like to tell my new, nervous to sailing pal that we were taking on water as we chugged across the calm glassy waters, so I made him a bacon sandwich, a cup of coffee and surreptitiously pumped the bilges again.
My Volvo dripless shaft seal has been in for err, around seven years I suppose. Its lasted less time than I had hoped, but more time that it specifies on the box, and we've done quite a lot of chugging over those seven years. So, the time has come to replace it. My late father did it last time around, and I must say I didn't pay nearly enough attention (oblique, none). The process, as I see it, is:
- Lift out (I need to lift out for a scrub anyway).
- Undo the shaft coupling (mine looks like the "confusing coupling" in Vyvs post here http://coxeng.co.uk/stern-gear/coupling-types-and-removal/) and little grub screw.
- Pull out shaft until the shaft seal can be removed and replaced.
- Replace with a Radice? (hurrah, no more burping) Lead a pipe from the Radice up above the waterline/top of cockpit lockers.
- Lead the shaft back to the coupling. Apply blue locktite to the four main clamp-bolts. Tighten back up (any idea what torque?)
- What torque do you tighten the clamp-bolts back up to?
- Once the clamp-bolts are released, do I need to use a screwdriver or the like to splay the clamp to release the shaft? Or with this sort of shaft the way that Vyv suggests here is the best bet?
- Is a Radice still a good bet these days? Not superseded by anything?
