markatcrockers
New Member
If Any of you who own a Boat with a Volvo Diesel are wondering why you have oil coming from the dipstick when the engine is under load, it is because of a known design issue with the original dipstick tube within the crankcase.
The tube fits into the crankcase and then a plastic extension fits over the neck of the tube culminating in the dipstick then sitting with its ‘O’ ring in the top.
What you can’t see is that the dipstick tube within the crankcase goes down into the oil and then bends at 90 degrees to sit under a baffle on the bottom of the crankcase.
If your engine is a little worn and the crankcase breather is blocked, pressure goes past the piston rings down into the crankcase, and hey presto you have a pressure vessel formed that the dipstick is sitting in. The oil is then forced out through the dipstick.
It should be noted that the replacement part from Volvo is now much shorter and does not have the crazy 90 degree turn and then sit at the bottom. It ends, after a short run in the crankcase allowing the dipstick to sit in the oil as before so that the correct oil level can be measured.
