Teddy
Can anyone give me some idea how you can possibly do an engine survey on the Thames (upper)? Clearly it will be impossible to run the engines at full power, so the engines will never be fully tested.
Is the survey then just a matter of checking the obvious once they have warmed up as much as possible? I have heard the word "Vodatool?" mentioned. Is this perhaps a diagnostic check which reveals all?
Are there likely to be any problems with a D4-210 which has been regularly serviced and has only done 220 hrs?
