svening
New Member
Hello
I'm wondering if you or somebody you know has experienced any Volvo D4/D6 engine failures. In Norway we are currently working on a case where about 30 engines have failed most likely due to dry fuel which cases an injector problem and a cranked injector copper sleeve.
Such an engine failure might not seem to be caused by an injector, but mostly such a failure is caused by loose of coolant due to a blown cap plug. Some engines also have a hole in the block.
If you know of any failed/damaged D4/D6, please PM me with the story. This will be very useful information as input.
