CHI
Hi
Maybe one for Volvopaul or spannerman?
Took my boat for a run early this morning after not using her for 5 months or so . The port engine would not rev to its maximum 3500rpm. Stbd engine fine. I also noticed that i had used more fuel from the stbd tank? I have racor 3201t pre-filters with clear bowls. Fuel looks clean, no debris or sludge. Checked fuel valves and all set ok. When engaging drive the port eng would not get above 2250 rpm. I could hear the compresser but not confident i could hear the turbo take over? Maybe because not revving high enough to cut in? Stbd eng by itself will rev to 3000 rpm as she struggles to get onto plane. Both working together stbd will rev out at max 3500rpm port only manages 3200 rpm and unable to increase eng speed if port throttle pushed forward. . Fuel filters due a change but i religiously treat my fuel .
No errors showing on my EVC display and all temps, pressures etc fine.
Any thoughts or ideas to check will be much appreciated.
Cheers
Keith
CHI
Cheers
Keith
CHI
