icordoba
New Member
Hi,
I have a coolant leak in my Volvo Penta D1-20B (well... a big hole... not just a leak). You can see it in the video attached (that is where the Elbow attaches to the heat exchanger block. You know, the manifold is part of the heat exchanger in this engine. You see only coolant drops as most of it is already out...)
I need seal that hole... as all my coolant goes out through the exhaust elbow. Any advice on this? I'd like to know if I can do this repair my self (using QuikSteel... JB Weld... Holts Gun Gum... or similar) or that whould be too risky and I'd better call a expert in this type of repair that would use a "professional" welding approach.
Thanks for any advice and greetings from Valencia,
Ignacio
Ignacio
