Medway Mudlark
A little under a year ago I purchased a Fjord 815, cos SWMBO said it was the right one! After having it on hard for 6 months rebuilding/replacing from the keel up it was deposited back in the water again, and until recently has only toddled around on the Upper Mudway. A couple of Sundays age we decided to give it a shock and take her to the salty stuff for 2 reasons 1. cos it was a nice day out, and second was to see what the engine/hull would do at higher engine revs than 1200. Most of the day was spent at around 1800 rpm apart off Grain where we took her to wide open, then throttling back to 3000 rpm. On checking the engine bay on the slower return trip I was greeted with a fair amount of water under the engine which had come from the filler cap on the heat exchanger, and the level was at the top of this. Prior to this the boat had spent the last 15 or so years up the Thames, The engine maintained its temp of just under 90 deg on the fast run and did not overheat. I am half tempted to run some rydlyme through the freshwater system, but something in my head says could this be the aftercooler matrix. Engine is an AQAD40b (165hp) on 280 SP leg. Am asking on here as there seems to be little mention of this particular engine and welcome your thoughts please
Regards.View attachment 54201
