moresparks
Hi, has anybody replaced the Bushing in the steering helmet (853048)? as fitted to the 290 sterndrives?
This is the one that the Bearing tap (852705) fits.
The bushing is approx. 40mm diameter threaded with 2 x 4mm slots.
When I had an insurance survey, I was advised (not critical) that at some point it may be worth replacing the bushings in case of “play” in the steering.
However… 30 years of stainless steel bushing in an Aluminum Steering Helmet and it doesn’t want to budge. Tried heat and penetrating oil to no avail.. Even tried a long steel 4mm thick bar but just succeeded in bending the bar. Not sure if there are other tools that can remove the bushing without damage to the Steering helmet.
Just thinking of polishing the bushing up and maybe replace the complete steering yoke assembly the next time I remove the drives for bellows change!!
Any advice appreciated.
