Chris_Robb
With overheating, its not always easy to tell if the problem is in the sealed system or the flow of water to cool the sealed system, and my earlier post referred to just the raw water system.
The sealed system does use the centrifugal type pump which relies on a close fit between the vanes and the back part of the pump to push the water around the engine and calorifier etc and it is possible, if this pump has had a repair kit fitted, that the new bearing/seal has not been pushed far enough into the housing or the solid impeller has been pushed a bit too far onto the back of the shaft, making the pump ineffective at low speed.
Vic and Happy daze, thanks for your contributions. I spent ages yesterday maiking sure that every last drop of air was out of the system. I left it ticking over after we had got into Kithnos (spanking close reach) and it did not move the gauge at all. So I think it really is down to the air in the system. I will just have to keep checking it but it does not take long.
Happy Daze - the water pump is the original and the raw water size pulls through tones of water - a bucket in about 30 seconds.
Thanks all.
