Tintin
I was hoping the removal of junk cable and fixing the multi connector would solve the problem but it hasn't, so some ideas of what to do would be appreciated pls.
The problem.....
Engine is a volvo 2003 of 1988 vintage with the standard panel.
With engine battery on and key turned pre-starting I only get the oil light lit, but no others.
Not sure if this is relevant but the backlight on the tacho works and the buzzer test doesn't.
On starting, the oil light goes out and the tacho stays dead and there appears to be no alternator output.
If I give it some revs the tacho comes alive and charging starts.
If I then back off the revs sometimes all stays good, sometimes tacho dies again.
I have squirted contact cleaner into the key switch and onto the multi connector at both ends.
Any ideas?
The problem.....
Any ideas?
