eddystone
Just having some second thoughts like do I really need to replace this engine? Having concluded now that my "steam" under load is maybe all white smoke no question injectors need doing, but engineer inspection (and he has a good reputation in the area) said oil spitting out of dipstick tube and heavy breathing evident when oil filler cap removed indicative of excess crankcase pressure oil blowing past rings (there is a film of oil over the water in the bilge). On a quick trip down to boat today I gave the engine a run. Although not under load as I didn't have time to go for a run, no white smoke even at over 3000 rpm, really good flow of water so no cooling issues (but definitely spits oil when dipstick removed) Also starts first time from cold. The suggested action was to have injectors overhauled, remove and skim head, replacing valve seats (and maybe exhaust valves) but recognising this may indicate more extensive overhaul needed. This would to me be acceptable cost if I get 5 years (250-500 hours) out of engine since the boat will probably be worth very little then with or without a newish engine. However, if dismantling shows need for more extensive overhaul e.g. rings and pistons, then a new engine makes more sense, I think. But if there is evidence that oil is blowing past rings in what circumstances could this not indicate the need for more extensive work than just a head job?
