karlfaeunst
New Member
Can anyone tell me exactly how the raw water cooling works on a volvo penta 2002?
I understand that the water is bypassed to the exhaust until the engine reaches a certain temperature. The thermostat then opens and some of the water is directed to the head to cool the engine, which then comes out of the top of the TS housing and along the exposed pipe to the other exhaust elbow connection.
What I don't understand is how this happens? The water enters the engine at the front of the block just below the thermostat and goes directly through the block to the exit pipe which is connected to the elbow. It looks like the the thermostat opens and blocks a hole when the engine is up to temperature which somehow forces the water through the engine.
During winterising it is said that you should run the engine with the thermostat removed to ensure that that water is passing through the block. However, if the thermostat has to be in the open position to block a hole then how can removing it make the passage of water take the route it would take when the TS is open?
It's probably very simple but I just can't figure out exactly what's happening, doe's anyone have any drawings or know how to explain it?
