ghostlymoron
I am struggling to understand the little silver box that controls the voltage apparently. There are six wires connected to it. What are they all for and how does the box work?
Yes dynastart again. I've got a silver box which I think is the regulator and a black one that I guess is a relay.
I guess that this is what it looks like internally. Ignore the arrow!![]()
Although probably not as pristine. I'm beginning to understand how it works.
Looks rather last century and I understand that there is a solid state equivalent which would be more reliable. Maybe I'll get one as a spare.
Re-VSR wire size. I think my main battery leads are 25mm2 so thats the max I can do. It's not the QE2
Solid state is a big improvement on the old mechanical regulators, giving a steadier and higher charge current. Usuallyunder £100, but you have to get the right one for your dynastart. The method of voltage regulation varies but some use an increasing voltage to raise the voltage output while others have to reduce the control voltage to increase output. Visualise it as variable resistance (which it isn't) either on the + feed reducing voltage or the - side increasing voltage to understand the difference. WHen I get home later this week I can check which way your unit works.
I'm aware of the advantages of an alternator but I'm stuck with the Dynastart and MD1 engine.
