simonfraser
yesterday morning i pulled 50m of 8mm chain up in one go, not under great tension, can see that by the chain flapping about as it comes up
the battery voltage dropped down to 11V with the KAD 44 idling (i normally pull up about 20m and then give the system a rest)
a 20 min run at 3000 revs sorted the low battery voltage
but, how to avoid this, when dropping the chain, i could put the engine in neutral and rev it to ? 2k in order for the aternator to at least put some charge back in
how effective would this be ?
leaving in the morning the engine is obviously not warm, so running it at 2k revs when cold would not be the best ?
what do others do ?
what do others do ?
