Tintin
Update
So I've had a play today, and as there is nowhere I can find within a 2 hour drive to buy components, and also because I am impatient, I took on board what Uber said about running them in series.
I looked for a ready made solution and found out that the cheap (£8 from Asda) 3 in one charger from Nexxus had a car charger to USB output (that you plug in various tips for different mobiles) that says it gives 5vdc <500ma.
It uses the MC34063a IC from TI (datasheet here) which is a DC to DC chip giving up to 1.5a.
I've roughly wired it into both strings in parallel and the voltage is 4.82 and the combined current is 0.54a.
The lights are (unsurprisingly) a touch brighter.
I'm gonna monitor the heat of the IC, but I think it will cut out if it gets too hot and that hasn't happened yet.
Taking on board the comments about LEDs neededing current limiting, not voltage, is it worthwhile limiting the current below what I am getting?
I've attached a few pics of the lights.
