VM Italian engines
lynallbel
29 Sep 2018
Yes, dreadful engine and fortunately never marinated to my knowledge. I was at LR when this engine was put into production. I much preferred the Gemini 200 and 300 engines.
200 is the mutts nuts, tough as old boots, I love mine, 300 also pretty good apart from some tit mounted the water pump at the top of the engine!
Td5 has a loyal following in lr circles, but lets just say there are always loads of td5 threads running at any time.
Sadly for lr every engine since the 200/300 has had issues, some of them quite serious especially cranks on the 2.7/3.0 v6 engines.
lynallbel
29 Sep 2018
Think later vms had one piece heads, pretty sure ldv vans had 4 cyl vms about 10 yrs ago, the van section of the wshop was always busy!
Bouba
6 Sep 2016
SoF
Having worked for Volvo and Mercruiser dealers for the past 25 yrs I can honestly say its Volvo that has payed for my houses, cars and boats. We experience very few problems with VM engines, they start on the first turn , don’t smoke and the 6 cyl is very smooth, I know there are more Volvos out there but even so I have never had to replace a head gasket on a VM or had to rebuild one, just the odd turbo and exhaust bend and ordinary servicing.
A few years back I was looking to get a boat with a VM engine. I did a lot of research and talked to as many people as possible and all agreed with your post! (ps I didn’t get the boat in the end because the wife didn’t like it!)
8 Apr 2020
I wanted to ask rafiki, but I forgot.
What's this 200 engine exactly? And on what car was it fitted?
Just curious.
2.5 litre 4 cylinder turbo diesel, used in early LR Discovery and Defenders. Later ones used the 300 TDI, basically the same, brilliant engines, reliable and last forever.
CLB
18 Jun 2013
many early defenders had VM engines. I think the 200 came in with the release of the discovery, so around 1990.
8 Apr 2020
I have never seen a Defender with a VM engine, the early Defenders i have seen had the 2.5 Turbo Diesel or naturally aspirated, i have seen the VM in early Range Rovers.
CLB
18 Jun 2013
You may be right. I have seen an 88ish defender with a VM and assumed it was the factory fit, as it was to the Range Rover at that time. If not, it appears that LR were fitting two different four cylinder 2.5 litre TD engines at the same time. I wonder why they did that?
CLB
18 Jun 2013
Can I just say that being in a Land Rover is not a ringing endorsement for an engine
Not too much wrong with the engine, it did well in plenty of other applications. I blame the Brummies fitting them ;)
8 Apr 2020
Probably an after market fit, pretty sure VM was not fitted in series/Defenders.
CLB
18 Jun 2013
So do you know what engine was installed to the 86-89 era of TD defenders? I'm curios now as it seems odd to have two very similar engines in your lineup. Perhaps there was a difference in the output, or maybe the VM was considered more 'refined' than the other one.
CLB
18 Jun 2013
OK, looked into it using the power of Wikipedia. It seems that LR themselves took their ancient 2.25 diesel and turned it into a 2.5 normally aspirated diesel. They then took this and turned in into a 2.5TD, so the 1980's defenders was still effectively using a 1960's engine. I guess it was a bit 'agricultural' for the RR, so LR probably wisely spent money buying in a more modern TD unit for its top-of-the-range motor,
michael_w
8 Oct 2005
My 1991 Defender had a 200 tdi lump. Never had an engine that was so eager to start, the merest touch of the starter and off she went, even in the coldest weather. My Disco 1 has the 300 tdi, not as good IMHO.
