Terra-Loon
Good job I didn't mention the dirty knife...
You need to curtail your point scoring and grow up Vic. If your aim is to try and prove to other forumites that you know more than me about internal combustion engines and their ancillaries, I'm afraid that you are doomed to failure.
It is totally inappropriate for you to rudely tell me to "RTM" for equipment that is not mine. That is up to the owner of the equipment. If you choose to do the same then that is your decision but to criticise me because I have not done so is pathetic.
The OP owner of the equipment simply stated that his charger can also be used as a power supply. On many chargers this requires a different setting to be selected to avoid the charger detecting a failed battery. The OP then clarified his problem by explaining that he was trying to use the charger with no battery connected (that information being obtained by yours truly asking further questions in an effort to help the OP) but the charger was not producing 12V.
The obvious first point is to check that the power supply setting has been selected, if there is one. If it has been selected, or does not need to be selected, then the problem is likely to be a fuse or switch, as I stated.
I believe that I covered these points in a systematic manner albeit without reading the manual and the OP appeared to appreciate my efforts to solve his problem.
You may wish to consider the above and reflect upon whether I am owed an apology.
Richard
You are doing an excellent job of a making your self look like an arrogant know all. keep it up!.. IMHO that is . but i know nothing. Not even that the OPs battery caharger was an internal combustion engine
Yes probably. " Closing" a switch means switching to "on"
I've read and re-read this thread due to the "conversational" tone (!) and highlight questions raised.
When plugged into shore-power my battery charger is "on" and thus feeds my 12v needs on board and also is keeping the battery topped up etc However my battery charger has two outputs for two battery banks but I only use one as my VSR controls the charging of my engine battery. So...................
a) is there any benefit of using the spare output to feed my 12v requirements independent of the battery charger ?
b) is there any drain (and thus battery life reduction - albeit small) on the battery when a battery charger is connected and a 12v load is applied e.g lights/fridge etc ?
In the meantime, may I offer my apologies to Rich as this is not what we would normally expect from PBO.
Richard
I can't see any way in which you could ever use the spare output "independent of the battery charger".
I interpreted it to mean "use one output to charge the batteries and the other output to separately power all the 12V ancillaries" which would require these two circuits too be isolated with relay or switch. Perhaps the ubiquitous 1-2-Both switch fulfils the first part this requirement (?) but you would then need cabling from output 2 to the house-side of the 1-2-Both switch or something. I don't have such a switch so could well be wrong on that.
It's not possible to use the battery charger independent of the battery charger, unless I'm being too pedantic! Regardless, it's totally complicated and quite unnecessary.
But the manual clearly states that it can be used to supply DC loads when no battery is connected!
No, you've missed the point. The question in post #45 was could he use a charger output independent of the charger. Obviously not. It's like saying can I use the shorepower mains without having shorepower.
Sorry I'd missed that post altogether and the thread has rolled over onto page 2 without me noticing
- a) He appears to be asking if their is any benefit in using a currently unused the spare output to supply loads as opposed to supplying them from the output connected to the batteries. I am sure he ( Caladh) is not suggesting he could do that without the charger being connected to a mains power supply.
- b) is there any drain (and thus battery life reduction - albeit small) on the battery when a battery charger is connected and a 12v load is applied e.g lights/fridge etc ?
The answer to a) is, "possibly" if the outputs are independent but only because the load will not hopefully affect the charging of the battery. We don't know enough about the OPs charger or Caladh's charger to be sure
The answer to b) is, " only if or when the load current exceeds the battery charger output and is connected to the same output as the battery"
Ok people thanks for your inputs on this, the result being that there appears no gain to powering 12v loads independent of the battery. However there are 12v inverters for fridges for example that auto switch to the mains if plugged in to shore power. IF there is no perceived loss in battery life running a load via 12v charger/shore power why would you use one when the batteries are being "charged" anyway ?
