Victron MPPT 100/50 Smartsolar - chassis grounding?
West Coast
23 Aug 2009
Clyde
Query for the electrical gurus here
I am fitting a Victron MPPT 100/50 Smartsolar controller at the moment. Installation is on a typical 10 year old 43' AWB with 12V systems and I plan to use this to charge the house batteries only.
There is a separate chassis grounding connection on the side of the case, not part of the main cable connections. Checking the installation instructions, it is not clear if a connection to this chassis connection is required or not, it just says that "Chassis grounding: A separate earth path for the chassis ground is permitted because it is isolated from the positive and negative terminal"
Should I be connecting the chassis ground to something, and if so, what?
Many thanks!
VicS
13 Jul 2002
ITYWF, at least according to the manual, the comment about chassis grounding only applies to the 30 amp model.
If however your 100|50 does in fact have a case earth terminal it could be connected to your main earthing point, but is is not part of the shore-power system, there is almost zero possibility that it could become live and I am sure cannot be considered to be an "extraneous conducting surface " so I don't see any need to ground it.
PaulRainbow
16 May 2016
Suffolk
Many thanks!
As Vic said, no need to ground it.
VicS
13 Jul 2002
I had the same unit and didn’t ground it. Worked fine.
It won't have any effect on how the controller works.
I think the earthing terminal is there to comply with US Coastguard/ABYC requirements.
Alex_Blackwood
19 May 2003
Fareham
It won't do any harm to "Equipotential" bond it to the mains earth connection. I would be inclined to ! Not saying Vic is incorrect, just waht I would be inclined to do.
