chasroberts
I wonder if anyone has any knowledge regarding the temperature sensor on a Centaur 12/40 charger which is fitted to a boat I have purchased? As soon as I connect 230V to the charger; the fans (both) start to run and then run continuously. The charger is connected to 2 battery banks both 12v (one battery @230Ah and a bank of 3 @230Ah total 960Ah). I appreciate that this charger is well below that recommended for a bank of this size but budgetary constraints mean that, for the moment at least, that I have what I have.
I assume that the problem is with the internal temperature sensor, but this is just an assumption. Trawling the internet has offered no solution or advice so far.
I have checked throughout the charger for hotspots but none are apparent with the largest temperature differential being about 2C above ambient level. This includes the heat sink.
The batteries all appear to be charging fine and are all less than 10 months olds.
I have tried emailing Victron directly but after 10 days have received no response.
Any thoughts on how to proceed would be gratefully received.
Many thanks in advance.
Chas
Chas
