santavey
Trying to sort out poor VHF performance.
Discovered voltage at VHF drops from 12.4 V to 12.2 when PTT on 1 watt.
But a massive drop to 9.6 V when PTT on 25 watts.
What should I expect to see? No drop, some drop?
Batteries OK. One is new. Set is Simrad non DSC wired through switch panel.
Would the VHF operate with only 9.6v i.e. not sufficient power to “push” the signal along 60 ft of co-ax and out the other end?
Is the voltage drop simply caused by inadequate or poor DC wiring or could I have a set problem?
Does the voltage (or power) required to “push” the signal along a a longer co-ax have to be greater than for a short co-ax. If it does that might explain why the set gives adequate but not fantastic performance when connected to a secondary antenna on a short co-ax run.
Lots of questions I know
Thanks in advance for any advice.
