rwakeham
I have been battling with the VHF radio ever since I have had the Boat. It is an Icom IC-M601. At first I wondered if the set was faulty, so borrowed one and got no convincing response to or from a handheld on shore. I have tried with and without the command mike attached.
So I then wondered if the aerial was faulty... so replaced the aerial and still no positive radio check. I've checked the aerial connections and can see no breaks in connectivity or loose wires connecting the shield and inner/outer cores.
The aerial goes into a Raymarine AIS box - and I get contacts from boats quite a long way. The situation is not improved when I take out the AIS from the equation.
Also have two handhelds so within the Solent we have been ok - but now venturing further afield and need something more substantial. They work better than the fixed set at the moment.
So what other tests can I run ? Could the AIS box need something other than just plugging in the right cables (nothing in instructions) ? Could there be something wrong with the power supply (the ageing fridge causes a buzzing on the radio) ? Or do I now just borrow another set and test again ?
Thanks in advance for anyones help.
Richard.
Richard.
