andyp
Hi,
One of our yachts has a problem with her VHF radio (ICOM IC-M503).
The symptoms are poor transmission range and when I checked with an SWR meter the reading was high (1:3 or greater) whether I used the masthead antenna, the stern rail AIS antenna or an emergency handheld antenna.
I don't believe a fault in the transceiver itself would cause this (apart from a breakdown of the TX/RX switch inside the box) so I wonder whether the root cause may be poor grounding of the transceiver itself?
Any advice welcome.
Any advice welcome.
