Bru
I reckon i'll be long abandoned when the batteries flood, the water needs to be at least a foot deep in the saloon for that to happen :ambivalence:
Don't abandon ship until you have to step UP into the liferaft
I've yet to have a fire on any boat that I've owned, so statistically speaking it's becoming more likely as time passes!
"Years back I had a handheld VHF with a BNC socket for the antenna. I could connect that to my masthead antenna, which was nice."
That's an elegant solution.
Looking at the problem from the other end, for the price of a couple of beers you can also make an emergency VHF antenna that coils up and stows away in a locker.
You need good quality 50 ohm screened cable. Remove about 18" of the outer sheathing from one end and throw it away. Now roll the screen (braid) back over itself and pull it down over the top of the outer sheathing. Now put a 50 ohm BNC connector on the other end. You've now got a 1/4 wave antenna that resonates at the marine VHF frequencies, works very well, and you can hoist it with a halyard.
Before you rush off and make one, best to Google and check the 18" figure that I've given you. I think it's 18 point something inches, that resonates on the Channel 16 frequency, and it also covers the surrounding marine band VHF frequencies. The closer you can get the stripped length to the ideal length for optimum resonance, the better it will work.
Okay. Just wish my boat was as comprehensively equipped as yours.
If you believe that I have some good gambling games we could play.
