2nd_apprentice
Can you mount a vhf aerial in close proximity to a wind generator or would it be likely to cause reception problems?
(Don't ask unless you has a background in maths and electronics or are really nerdy).
Yeah well, maths was never my strong side really
Shame about that. My aerial is mounted on the pushpit and having just ordered a 2m mounting kit for the Rutland I thought I could have something welded onto that. Probably a daft idea!
No not really. The advantage of aerial up that much higher would be worth the effort. Most I think wind generators use 3 phase pick up windings and a rectifier in the control box. Or possibly rectifiers in the generator. either way it is unliukely IMHO that interference will be a problem. However if you leave the antenna on the rail it may well be shielded in transmit by the post and turbine. good luck olewill
