I own a Swiftech M198 handheld VHF radio with a 700mAh 9.6 volt battery. According to the instructions this can be powered externally by a 12 v battery or charged with 240 volts. As my boat has no onboard battery I have (after discussion with our local chandler/electronics man) used a De Walt rechargable drill battery rated at 12 volt 1.25 Ah this worked fine until I tried to charge the radio's internal battery which is now dead and will no longer accept a charge. have I somehow damaged the internal battery? and if so what is the difference between a drill battery and a "normal" 12 v unit I hope someone can shed some light on this one
