sparkie
Just bought a new antenna (Banten) cable and plug complete. The (minimal) instructions for connecting the coax to the antenna appear to indicate that the inner core is not stripped but merely shoved up into the antenna base with the sleeve intact. Does anyone know if this is correct? Surely a metal to metal contact is required at this point? Don't want to make a booboo with the mast down between tides!
Also, when testing the antenna connection with a multimeter, there appears to be no electrical separation between the outer metal and the inner core socket. Presumably this is correct, but how does the screen work if it's all connected together?
As you will guess I'm not really a sparky, despite the pen name!
Sparkie
Sparkie
