Vetus engine panel
vic008
18 Aug 2007
CHCH. NZ
that has relays, well would I be permitted to throw them out, because will be so much easier to figure out how to wire without the extra complexity of relays ? So are the relays essential?
There are presumably relays for glowplugs and for starting. Anything else ?
Not sure I understand why relays make it that much more difficult to "figure out".
You would probably not be able to throw out the glowplug relay but you may be able to throw out the starter relay although doing so would probably necessitate uprating the wiring and the key switch.
