Very tapered pipe thread: anyone know what it is?
jdc
1 Dec 2007
Falmouth
I wonder if anyone knows what thread the one on the top is? It's 14 tpi and I think is the same thread form as 1/2" BSP, but the taper is much greater than the 1 in 16 of BSPT, as can be seen by comparing it with the example of 1/2" BSPT on the bottom in the photo.
It's on a gas bottle, so maybe '17E' but I can't find a dimensioned drawing or spec for this (nor for 25E which I'd also like) except if I buy ISO 11363 for >£100, which is rather a lot on the off-chance it is described within!
Many thanks for the copy courtesy of the Indian standards body. From that I gather that it can't be 17E as its taper is only 1:16. Others are 1:8 or 3:25, but not that small a diameter, so I still don't know what my thread is.
It could be NPTF (national pipe taper fuel). This has an inclusive angle of 8 degrees which is just over double bsp which is about 3.5 degrees (1:16). The idea of the larger taper is so it seals without the use of sealant. Possibly the female part will be tapered too.
