Feneris
Here's one of the photos of the boat, from the ebay advert, which encouraged me to buy her.
It's a Sunseeker, believed to be a 'one off' S23, made to be 19ft. The engine is an a Volvo AQ170B with a 280 sterndrive. This puts the year of manufacture around 1972. It's my first boat. I bought it, unseen, after a long chat with the owner. Now I know a bit more about boats I've realised how lucky I was to get a good one!
The engine had a rebuild done on it a few / 5 years previously. The boats interior was in need of refurbishment. The fluted vinyl has become very brittle and was starting to fall apart.
I removed the vinyl, the ply it was mounted on was rotten, and held on with steel bolts (angle grinder to remove). It delaminated all over as I pulled it off.
Most of the wood in the boat is in really good condition and repairs are cosmetic rather than structural. The fibreglass seems sound throughout and all fixings into it are absolutely solid.
The wiring was made up of decades worth of electrical tape, mods and updates.
I removed all wiring, and have rewired with marine grade cable and a minimum number of good quality connections.
I've remade the marine ply sides that the fluted vinyl is mounted on, and ordered the vinyl from Hawke house.
The cuddy cabin was wall to wall shag pile. It was filthy and falling apart; I removed it in clumps and the rest with a scraper. I've still got a lot of glue on the fibreglass which is slow to get off. I've ordered a 'glue remover' for my angle grinder (hawke house again), it's a soft disk which should remove glue and not damage the glass, I'll give it a go next week. I'm waiting on a couple of interior carpet samples to decide which to use. I'd be happy with shagpile again! I carpeted my VW van with carpet from megavanmats, and may use this again. It costs about £100 inc high temp spray contact adhesive.
On the mechanical side I've had a few probs. Removing the thrust washer from the prop shaft took over a day, see other thread. Also, when I drained the oil, it looks like there has been an ingress of water into the sterndrive.
Both the bellows had water in them, and small holes. I'm hoping this is where the water got in. I'm yet to seek advice on what to do about the sterndrive. I've had to take the top gearbox off to get the drive shaft bellows off (I couldn't remove the screws holding the pivot pins in, so split the gearbox instead).
There's a lot of play in the steering mechanism.
Does anyone recognise this mechanism, can I get a new cable / service kit for it??
My main question for now - is the fibreglass hull made from epoxy or polyester resin? Is there a way of telling without gluing samples to it? As I understand it, if the hull is polyester, I should used the same again on any glass work, and epoxy if it's an epoxy hull. Is this right??
Also there was a leak from somewhere into the cabin. I've removed the hatch to re-tape it. Before I re-carpet the cabin I'd like to seal everywhere I can, around the fixings, that go through to the outside. What's the best glue/sealer etc to do this before I cover it up??
Cheers for any advice, and I'll keep updating progress over the next week or 2.
