lpdsn
But I keep asking you to re-read post #29 because I'm sure that the only reason PRR mentioned ladders is because the post before his mentioned the boat falling 4m as the tide goes out. The ladder is therefore presumably needed to climb down back onto the boat from the harbour wall.
What continues to confuse me is how that relates to any of your posts?
Richard
Post 29# he says "in this case the only option is to tie up to a ladder..."
I say it isn't. I'm even saying it's not even a good option.
When tied up to a wall you have two long springs (and bow line & stern line - note bow and stern line in the traditional usage, not breast lines called bow and stern lines in modern marina usage). If you make sure they're loose enough for the expected drop of tide the boat will often drift off from the wall, with the springs hanging alongside the boat - more tension being on one than the other depending upon the wind direction etc. Being a few feet, sometimes a good few feet, off the wall is no problem, you grab one of the springs and pull - sideways pull just like sweating a halyard. This will work against the other lines and the boat will come into the wall, at which point you step onto the ladder. No need to exert any huge force, a slow steady pull will achieve the goal.
Works well for me at 4 or 5m ranges. Works well for other boats that I usually see doing pretty much the same.
Edit: And in the hope of cutting another cycle of posts short, you can do the same from the shore to get back on board, although if single handed and the boat is likely to drift off quickly you have to be a bit nippy about it.
